I have a set of 305-50-20 tires in my backyard. Will those fit a 2001 2wd F150 with stock suspension?
Mileage is 1 or 2 less per gallon but cost is usually $1.00 less per gallon as well. So it's still worth it. I guess I should also mention that on my system the propane is injected at the throtle body. The newer systems have 8 individual injectors. There is zero power loss and some say even better mpg.
Welcome man! And i guess you could just go back to normal stock, but with some 265's 1.5'' level and stock spindles with no rear blocks.
I'd say do an airride system, so you can slam it while cruising and have it stock while going over speed bumps and junk
