Well I'm screwed
Discussion in 'General Discussions' started by Sl33p3r, Aug 21, 2011.
  1. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    Ok let me get this out first **** **** **** **** **** ****
    Ok I tried to fix the misfire and I was low on water I came to my gf's it was runnin hot n I filled er up. So I get back to the gf's house n I'm over heated. So I checked the oil on the stick n it was fine then I take the oil cap off n water oil mix galore I'm like fuuuuuuck. So anyone know where it's leaking at? And about how much would it run to fix it? Is there a way of cleaning the water oil mix out of the motor?
    Sent from my bad ass phone
  2. BlackThundah
    I think its time to buy that, chevy you looked at the other day and turn that fiddy into a mudder
  3. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    This fiddy has turned to junk. I'm thinking head gaskets n oil change plugs n some seafoam could fix it. But idk about new engines. In the Chevys if I had a problem like this I would rip apart the motor n rebuild it for more power.
  4. The Batman
    The Batman Rest In Piece
    cold hill ky
    was it just on the cap or was the mix on the dipstick too?
  5. THEPRODJECT01
    THEPRODJECT01 MARKK
    odum , ga
    i would sell your truck, before it all gets worse
  6. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    I did the dipstick first and it seemed normal. Then I took the cap off n seeing it makes u wanna go on a rampage. I'll get pics in the Mornin
  7. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    I just got a txt from a 17 year old I told him I will fix it before I sell it and told him a price if fixed and he says dam that's high I only make 200 a week. And I'm sitting here like where the **** do u work lol
  8. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    If I can fix it and have it run right I'll keep it but if not I'll just build a 4.6 n keep it. I just want it to run till I get the money to get something else. The asshole partner took over the farm n cut my pay and quit paying my dad n his disability check hasn't kicked in yet.
  9. TLSF150
    TLSF150 Full Access Member
    Stockbridge, Ga
    +1 if its the cap it could just be condensation.. If you buy that chevy maybe you should treat it better and it will last longer.. Just sayin.. :pp:
  10. Darth Bama
    You can only pound on a vehicle for so long before shat starts breaking and falling apart. Good luck on whatever path you decide to journey down.
