Switchback LEDs
Discussion in 'Interior' started by ak_cowboy, Jan 18, 2011.
  1. rrogers
    tow mirrors fo sho
  2. iFX4
    iFX4 Chief
    Florida
    dude those are badass!
  3. DarkShadowSTX
    DarkShadowSTX the "brat"
    Brecksville, OH
    for those of you wondering,
    i have these switchbacks: TYPE 2 DUAL COLOR CHANGING HID 5K WHITE AMBER SWITCHBACK 60 M-SMT TURN SIGNAL BULBS 3157 3157NA 3357 3457 4157 4057
    and this flasher, to correct the turn signal hyperflashing as a result of switching normal bulbs to leds for the turns: Buy Tridon (Novita Tech. Inc) Electronic Turn Signal Flasher EP27 at Advance Auto Parts
    v-leds also has a flasher that should work the same: http://www.v-leds.com/BlinkerWarning-Fix/Electronic-Flashers/5-PIN-ELECTRONIC-LED-p4810389.html
    is is located here in my truck and looks like this:
    jarrett, your turns are bulb 3157
    i will gladly answer any other questions you guys have :cheers2:
  4. cowboy
  5. 01f1502wd
    so I think i will do alllll of my lights. for my taillights will i need that special relay? and what about the blinkers in my mirrors?
  6. DarkShadowSTX
    Brecksville, OH
    if you get the flasher/relay, it will only be a one time install. it will fix flashing issues whether you have front turn leds, rear turns or both.
  7. 01f1502wd
    done. next mod after i get my BIG 3 and all of my wires straight and all nicely put away.
  8. DarkShadowSTX
    Brecksville, OH
  9. ak_cowboy
  10. DarkShadowSTX
    Brecksville, OH
    Vleds is where I got mine. Still working flawlessly
    Sent from my DROID X2 using Tapatalk
