Conventional oil vs Synthetic oil
Discussion in 'General Discussions' started by westtnfx4, Dec 15, 2010.
What kind of oil do you use?
  1. Conventional
    5 vote(s)
    23.8%
  2. Synthetic
    10 vote(s)
    47.6%
  3. Synt blend
    6 vote(s)
    28.6%
  1. Darth Bama
    Penzoil makes a killer Synthetic from what I've read online. I may check into the ol' WM brand!
  2. backwoodscountryman
    Backwoods
    I run Castrol Syntec fully sythetic 5W20 with a Wix filter.Both are good products overall.When i switched to my castrol syntec and started running it,about after a week of running it,engine tick was gone.
    I heard Royal purple in the winter time is not always good for those harsh envirements.Have heard it from several diferent mechs and a few online forums.I do run Royal Purple in my front and back diferential.I like it.
  3. FLfirefighter
    Parrish, Fl
    Conventional is what i have been running for years with Fram filters, only problem ever had was i doubled gasketed it on the wifes exploder. And i Got over 307,000 miles on my beast[​IMG]
  4. supercrewzn
    Yup, that truck had coils, egr valve and some emission sensor replaced in it too. I don't remember the name of that sensor.
  5. Darth Bama
    I can tell you right now, it was the DPFI sensor. :jester: If the EGR was replaced I can almost guarantee the DPFI was replaced at the same time or shortly after.
  6. ak_cowboy
    5w-20 royal purple with K&N filter.6000 mile changes no problems. Blackstone analysis showed everything great after 18,000 miles. RP is more expensive initially, but you double the oil change interval, which cuts the overall cost in half. Fwiw, $9/qt here.
  7. '02F150CountryBoy
    Southern Alberta, Canada
    Shell conventional 10w30 (its thicker and slows the leaks:jester:)and fleetguard filters in my '88. Might see bout changin it up with the new rig but probably not, other than to 5w30.
  8. supercrewzn
    That might have been it. It was related to the egr system some how...Bawahaha
  9. iowaredneck
    Ran conventional in all my last trucks and did fine with those, but I just might switch to syn blend on this truck, I have not done my first oil change yet, it was done when I bought the truck.
  10. VanoFord
    RP FTW!!! I have had that in my truck since the first change.
    Engine = 110k w/ 105k on RP
    Trans = 110k w/ 85k on RP
    Rear Diff = 110k w/ 90k on RP
    Its a bit pricey, I agree, but the first time I swapped the engine, I felt the difference. It does add HP, like maybe 2-5 tops, but I felt it. Motorcraft Filters, and NGK Spark Plugs (allows me to advance timing w/out any troubles).
