Nether is going to really hurt anything I believe as long as you dont do so real hard core off roadin. At least thats what I think
It re adjusteds your cv axel postions but cranking your tbars does too right? And if you get a tire alignment it shouldnt cause problems right?
a 305 is a 33.8" tall tire ..... so yer 305s are taller than 33s ..... tire alignment dont have anythang to do with cv angles ..... the more yer tbars are cranked the farther down it pushes your tire , therefore puttin the joint at more of a angle .... versus stock keys not allowin u to push them that far down ...
Yeah but if you put like a 10 deg positive camber on those babies the CV angle should be just fine ...right?
