Dash board lights
Discussion in 'Interior' started by Pity7700, Jan 29, 2011.
  1. cowboy
  2. supercrewzn
    Your looking in the wrong place bud because LEDs are cheap.
  3. cowboy
    you talking to me thomas or Pity?
  4. Warspite
    Warspite Member
    Atlanta, GA
    Just did the headlight switch as proof of concept - which did require soldering longer leads onto the T10 LED, and wrap them like the old bulb. Looks GREAT (be careful to try it more than once, as polarity is not indicated, so if it doesn't work on the first try, rotate the bulb assembly 180 degrees. I just guessed right. LED (cool white) was about $2 each on average (I also ordered 194's for the gauge cluster). They are worth it!
  5. DestinationFX4
    pics?
  6. supercrewzn
    agreeing with you and talking to pity
  7. Warspite
    Warspite Member
    Atlanta, GA
    Completed LED swapouts, and the results are as follows: Gauge cluster was left unmodified, so it still had the blue film. Cool white LEDS now display ice blue - like Supercrewzn's paint! Temp panel went the same. Headlight switch panel did NOT have the blue film, so it's cool white, which I will leave alone, until I decide on a new head unit, which nowadays can be adjusted to match any color. Forgive image quality, or lack thereof - it was done with a phone. The temp panel matches the gauges more closely than the photo shows. Light switch panel was a joy (OK, curse words deleted). But, cool white is still better than the DARK it was, since bulb was blown.
  8. Pity7700
    lol youre right the LEDs are cheap its the fricken shipping that was going to kill me.
  9. Warspite
    Warspite Member
    Atlanta, GA
    You can get them in a lot of 10 (that's how I got my 194's), so shipping was only a buck more than a pair. eBay has thousands of listings for the same part, probably from the same supplier, so look for a "bulk" deal (some will combine shipping, and have a calculator for it - and others will charge you as if you made 10 separate orders - the Bastards!). I used 5 194s for the gauge cluster, 2 for the temp control, and 2 more for the doors. One spare.
  10. Pity7700
    i never looked before but can the bulbs come out of the little twist and lock pieces? or is that all one peice. just wondering if i can buy just the LED bulb and swap out the old bulbs or do i need to get one already in one of those black twist and lock pieces
