ah crap
Discussion in 'General Discussions' started by Thumper4x4, Sep 22, 2011.
  1. Thumper4x4
    Thumper4x4 Full Access Member
    Arizona
    well i was removing my exhaust manifolds to put my headers on and i got down to my last two studs on the passenger side and all i did was give it one wack with the air hammer and bang both broke off in the head, anyone no how to get studs out
  2. supercrewzn
    Are they sticking out of the head at all??
  3. TxFx04
    theres a tool you can use to extract head bolts
  4. Thumper4x4
    Arizona
    no each one broke off about 3 threads into the hole. there the upper and lower back ones on passanger side
  5. deboer03150
    deboer03150 Banned
    Archer, IA (Northwest, IA)
    left handed drill bits and easy outs. if that doesn't work you'll have to drill them out compleatly and retap the threads
  6. supercrewzn
    This always works but I dont know if it will melt the head. Take a nut and weld it to the broken stud, then you can put a socket on the nut and get em out.
  7. deboer03150
    deboer03150 Banned
    sorry broh but this wont work in this case. he said the bolt snaped about 3 threads into the head. you can only weld a nut to the bolts if they snaped outside of the head.
  8. Big'un
    easyout , same thang happen on my scab
