Dash board lights
Discussion in 'Interior' started by Pity7700, Jan 29, 2011.
  1. Warspite
    Warspite Member
    Atlanta, GA
    The 194s and 37s (72s) are ordered bulb-only. The old bulb comes out of the twist lock and the LED goes right in its place, just like a replacement bulb, so you can re-use the existing twist locks (I had extras from a wreck sitting around). That'll cover the gauge cluster and temp panel. Headlight bulb is a pain in the posterior, but with patience and solder, it can be done.
  2. supercrewzn
    You can make the ac panel match the headlight switch if you want. Just take the ac panel apart and pull the blue film out, it comes out in one piece.
  3. Pity7700
    alright cool. i just ordered some bulbs. should be here sometime this week.
  4. lovemyfx4
    lovemyfx4 Full Access Member
    elburn il
    ok so maybe its just that im tired and cant think very well right now. (done 3, 4 pg college papers in last 2.5 hours) but i tired this awhile back and ordered the wrong bulbs so which do i need for a 2002 f150 dash?
  5. Warspite
    Warspite Member
    Atlanta, GA
    I believe that gauge clusters 2006 and earlier use:
    7x T10 Wedge LEDs (aka 194/161, your choice of color). 5 are for the cluster, 2 are for the HVAC controls
    2x 74 (aka 37/73) LEDs. These are the 2 smaller ones that fill in the upper part of the gauge cluster. Some list these online as T5.
    Make sure that these are "wide angle" - there are many to choose from, and some come with intensity ratings (measured in Lumens).
  6. Pity7700
    whats the difference between a 90 degree wide angle and a 120?
  7. Warspite
    Warspite Member
    Atlanta, GA
    The higher the degree, the wider the throw of light. These dash clusters actually need 180 degree to best mimic an incandescent bulb as far as light pattern. So, go for the highest degree that you can get. If you check the pictures I posted, those LEDs were actually an assembly of 9 LEDs per "bulb" to get wide angle coverage. As a result, the ones I installed arent SUPER bright, but very comfortable, with minimal "hot spots' that you get with narrower (lower degree) LEDs. These are what I installed (9 LED, not listed as super bright, cool white)
  8. Pity7700
    well ****. i bought some 90 degree widebeams. i thought the 120 would be too intense
  9. Warspite
    Warspite Member
    Atlanta, GA
    Try them. Worst case, there might be a "dull spot" on the tach near 2-3000 RPM.
  10. Pity7700
    yea plus i only spent .79 per bulb. if they arent bright enought ill get a brighter one with the 120
