SCrew Window Master Switch
Discussion in 'Interior' started by VanoFord, Dec 16, 2010.
  1. VanoFord
    So the Driver Window up JUST went out. all other windows work perfect... anyone know of a way to fix it (crossin wires?) til I get home? I dont mind gettin a new one, but damn it looks like rain this afternoon...
  2. cowboy
    I think I got my Haynes manual in the truck. I'll check in the next 20 minutes and post what I can find for ya.
  3. VanoFord
    yea, I got mine at the house. i'm bout to head home. I'm thinkin a battery and crossin some wires will do the trick. I'll see. Gettin a new one tomorrow...
  4. cowboy
    book doesn't show much. blue/tan going to the switch to the motor and back out. Not sure if it's a 12v motor or not. I would look at the passenger side and measure the voltage as you drive it up and down. But that sounds like too much work if your going to get a switch tomorrow.
  5. VanoFord
    A solution to the problem...
    So, I couldn't get the window to roll up by crossing wires. I couldnt even get it to work by using other switches. The main switch has all 8 pins. All the others, even the rears, have some variation, 3-5, but not all 8.
    By now the window was all the way down, and its supposed to be in the 40's when I go to work tomorrow (i know thats a balmy 40 for some of you...). What I did was take apart the controls completely to see what was actually the issue. turns out that the connection was worn, part of the paddle had actually worn off so it was further from the pin. Soon as I pressed with my hand, it worked. Now, this just solved the issue, not the problem. Since I am never in the back rolling the windows up or down, I decided to take apart one of those and swap out the paddles. Now I know the pics arent best quality, but you should be able to tell what I did. I know, cell phone pics suck close up. I suggest anyone else check this prior to going to the stealership and droppin $75.
    Thanks cowboy for brainstorming w/ me. And you were right, usin the meter while tryin to roll it up was stupid difficult. needed atleast a 3rd arm. haha.
  6. cowboy
    no problem dude. I just use the one I got growing between my legs when I need a third. :)
    I would check around the junkyards. Or check http://www.rockauto.com
  7. agjake11
    agjake11 Suck my tailpipe
    Rosenberg/Baytown TX
  8. rrogers
    mine did this same shit a while back i cleaned the contacts and no trouble since
  9. supercrewzn
    don't forget the expy switches will work also. Just get another switch and fix the rear one.
  10. PJB
    PJB Full Access Member
    Rotterdam, NY
    Keep playing with it and it might go up.
    I was having some issues with my driver's side front window switch and now its fine. I didnt take it apart and somehow it fixed itself.
