Should I trade my Ford for this Chevy??
Discussion in 'Other Vehicles' started by westtnfx4, Oct 27, 2011.
  1. TFIDDLE
    The people with those chevys like that with keys and a lift around here have no power because of gears, frame breakages!!, and tranny problems.
  2. DestinationFX4
    check to see if its losing oil too...almost everyone i know with that body style chevy and the one before had their rear main seal go out around 60-70k.
  3. westtnfx4
    All good input guys thank ya :cheers:
  4. J.Wal
    I ant gonna Bs and say I know anything much about them. But I do know to me the interior, especially the dash seems cheap, creaks and rattles while driving
  5. VanoFord
    my uncle had this body style, 2500 gasser. he went through 2 tranny's, and he was runnin stock rims/tires & no lift. he was a diehard chevy until all that problem. Now he's a P-Stroker and wish he had been one from day one.
  6. westtnfx4
    Hmmmmm here's what he texted me this morning "Nope they a Straight across this new lift from fab tech fixes that problem I could send a pic of it"
    So he's going to send pics after work....
  7. supercrewzn
    Cheap interior which rattles constantly, intake issues(gaskets), fuel pump issues, electrical issues (cluster), there a cheap made truck. Wheel bearings usually go out around 100k (100 bux a side) ac tensioners are garbage. Gotta replace belt and ac tensioner together. LS motors have a seperate belt and tensioner just for ac.
  8. The Batman
    The Batman Rest In Piece
    cold hill ky
    if you trade your ford for a damn chebby you shall be banned!!!!:shooter:
  9. supercrewzn
    Oh I forgot to mention, my buddy has an 03 with 155k miles. He got a cel for knock sensor. I replaced them (under intake) light went off for 2 days. Next code was oxygen sensor, those were replaced and light was off a day. Next code was random cylinder misfire. Replaced wires and plugs. Now it's back on for injector malfunction.
    4 different codes in 4 weeks....:facepalm:
    An ex of mine has had to replace water pump and instrument cluster and hers only had 75k miles.....
    Another buddy has a 02 HD with 6.0 gas motor.
    122k miles and he's replaced water pump, fan clutch, and had to pull heads because the exhaust stud broke off in the heads....
    Chevy=FAIL
  10. Screamin.03HD
    Lexington, TN
    The knock sensors can be a real pain if mud ever got to it..they break all apart
