Poping noise from front suspension when in reverse
Discussion in 'Lifted' started by Turkey Hunter, Dec 18, 2010.
  1. Turkey Hunter
    Turkey Hunter Full Access Member
    Lebanon Virginia
    Well when I put my truck in reverse there is a loud poping noise from somewhere in front of the driver side. I'm affraid its the front differential but I'm not positive. It only does it in reverse. Any ideas on what it could be. Ill check the fluid in the front differential 2morrow.
  2. The Batman
    The Batman Rest In Piece
    cold hill ky
    does it do it in 4x4 too???...does your 4x4 engage rough or pop when engaged??...does it only do it when you bach up or does it do it when you turn in reverse???
  3. Turkey Hunter
    Lebanon Virginia
    I haven't tried it in 4wd but u will and ill have to see if it does it while turning
  4. The Batman
    cold hill ky
    put it through those paces and see what it does...that way we can narrow it down to the most likely culprit...keep me posted on it ok?
  5. Turkey Hunter
    Lebanon Virginia
    Alright I'm goin out with the gf in a little bit ill test it out then and post the results on here
  6. The Batman
    cold hill ky
    :hmm:
  7. cowboy
    I say its your wheel bearing bub.
  8. Turkey Hunter
    Lebanon Virginia
    ^theres no play in the wheel.
  9. The Batman
    cold hill ky
    What did you find out???
  10. rrogers
    having the same issue so curious to see what this may. mine is not bad at all though anad i have not even tried to figure it out yet.
