i think i found my leak
Discussion in 'General Discussions' started by mustangwarrior, Nov 1, 2011.
  1. mustangwarrior
    NE Ohio
    im almost positive this time that water is getting inside the door and running down the inside and coming out of the holes in the bottom, when i opened the door earlier it all ran to one end and poured out, so the only way for it to get in is between the window and rubber or between the mirror and door
  2. The Batman
    The Batman Rest In Piece
    cold hill ky
    :hmm:
  3. Screamin.03HD
    Lexington, TN
    That's false..if there is a gap anywhere in the silicone that seals the windshield it'll run right in. Pop ur cowl panel off and check the seal
  4. mustangwarrior
    NE Ohio
    already have, windshield doesn't leak, just put in new door seals and siliconed the rear window, i've been chasing this leak for almost a year now and have pinpointed it to certain areas, water pours out of the holes in the bottom of the door when you open it and one of the factory holes lines up perfectly with the wet spot on the carpet, might also explain why the bottom of the door is also rotted out
  5. iowaredneck
    :hmm:
  6. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    mysterious water attack
  7. big cube 426
    big cube 426 Junior Member
    i chased a leak in my 07 for 3 months, finally gave up and called a guy called the water doctor. he found the leak in 2 1/2 hrs. it was the bottom windshield clip on the drivers side.
  8. supercrewzn
    :hmm:
  9. big cube 426
    ^^cant figure it out??
  10. mustangwarrior
    NE Ohio
    ok i definitely found it now, its leaking in between the window and the outer seal just like i thougt some time to drop another $50 on the damn'd ole truck
