  1. ak_cowboy
    How hard would it be to up the front from 11" to 15"+ ? It seems like you could do a lot with the money saved from getting the midtravel first. $1600 vs $5000+
  2. 01f1502wd
    well right now I dont do 100+ off road so a mid travel would be excellent for what I do..and I do jump it every now and then.
    I would replace the entire front end. they run coil overs. this set up still uses coils but theyre less stiff. I may look into converting it to coilover though...shouldnt be hard, just need to plate the lower arm then strengthen the upper and thow it in.
    Sounds like you know what you want to do... :driver: :chewie:
  4. 01f1502wd
    yup. and im thinkin about changing my mind on my engine too. do a L swap instead of the vortech, then it would be easier to get parts and easier to modify cuz all i would have to do is get L parts.
  5. ak_cowboy
    or just swap the entire L engine over and get different pullies :peace:
  6. TxFx04
    you just need to do AND finish one mod at a time :jester: you change projects too much
  7. yz85rider2002
    Yeah finish one mod at a time. But I may know someone interested in a vortech
  8. 01f1502wd
    ^full kit with an innercooler. I paid 1200 for the kit and 600 for the innercooler. install it and tune it and your good. so 1800.
  9. yz85rider2002
    Yours is a 5.4 right?
  10. 01f1502wd
    yessir!
