Poping noise from front suspension when in reverse
Discussion in 'Lifted' started by Turkey Hunter, Dec 18, 2010.
  1. che22879
    che22879 Big Dog Che
    Los Angeles
    its the sway bar end links, they wear out like ball joints, its an easy fix.*edit* at least on 2wd trucks its usually the culprit.
  2. Turkey Hunter
    Turkey Hunter Full Access Member
    Lebanon Virginia
    It didn't do it at all tonight. It seems to only do it when then the truck is cold.
  3. Turkey Hunter
    Lebanon Virginia
    Ill experiment with it more 2morrow and try to get some more info.
