4 in or 6 in cant decide
Discussion in 'Lifted' started by MPSoldier, Aug 29, 2011.
  1. 4ctNduction
    T-E-X-A-S
    beat me to it. you could have a 30 in lift, but if you had 32x10.50s on it, it wouldnt matter haha
    just get 4.5-5.5" of back spacing and you should be set :peace:
  3. MPSoldier
    MPSoldier Full Access Member
    New York
    So I was looking for the leveling kit im ordering on hbs and I saw that they have both the 2.5 and the 3 in leveling kits...........is the 3 in too much ?? Never seen them do they look better or worse than the 2.5? And also will they start causing problems
  4. Carolinaboy
    2.5" I don't like the 3" CV angles on the 4WD
  5. iowaredneck
    3 will cause problems. don't go bigger than a 2.5
  6. DestinationFX4
    what these guys said!
  7. MPSoldier
    New York
    Alright re-visiting this subject. For now I am doing the 2.5" level and 35's. But sometime int he next year I will probably get a 6" lift. I have been doing some research and found two kits that are the same price. Rough Country and Zone Offroad. Only problem I am running into is that I have never heard of zone offroad and I dont know what all has to come in a lift kit.
    Links
    Zone Offroad
    6" Suspension System
    Rough Country
    Ford Suspension Lift Kits
  8. TxFx04
    i'd go with rough country has a little more quality than a zone. zone lifts are good but i hear the shocks are terrible. the rough country kit has a high clearance drop crossmember and it looks alot better imo. J.wal has a RC. i can't wait to get my 6"RC
    Both feature the 6" spacer but you can always swap out the stock strut and spacer for a 6" bilstein 5100 if you wanted to
  9. MPSoldier
    New York
    I dont know what that means. You might as well have spoken spanish
  10. TxFx04
    :waytogo:
    bien, bien el país tiene una caída aproximada aclaramiento elevado en comparación con el travesaño hasta el ascensor Zona. Me gustaría recomendar el país áspero, la calidad es mejor, las crisis son mejores, que dicen disponer de bloques en la parte posterior que eliminan envoltura del eje. soooo sí
