removing body lift
Discussion in 'Lifted' started by jparks54, Nov 29, 2011.
  1. jparks54
    jparks54 Full Access Member
    Canton, Tx
    ok so i have a 3" body lift on my 01 f150 and i am ready to take it of its just looks horrible i know alot of you wouldn't suggest this but im doing it... so my question is i dont have the factory parts were can i find the info on what bolts and bolt sizes i need? i will be picking up a fan shroud from a salvage yard to fix that problem and the crush blocks under my bed are just tacked on so they will come off easy. thanks for the help in advance.... oh and i have searched but found little to nothing
  2. supercrewzn
    My suggestion would be to grab the bolts you need when you get the shroud from the junkyard.
  3. VanoFord
    ^^^ good point.
    you might be able to google the body lift manufacturer, and find a instruction manual/installation guide as well. in that should be what bolts get removed, and could help.
  4. jparks54
    Canton, Tx
    im the one that installed the lift and i found a copy of the instructions but my parts got thrown out when we moved i think i will just pick up the bolts and a few other things i had to cut when i go just have to see if they have a couple of my trucks in i can take parts off im also looking for a solid rear window because the latch on my sliding window is broke
  5. Big'un
    Thats a job
  6. 2001_4.2
    2001_4.2 Full Access Member
    Lets see a picture of how it looks!
  7. jparks54
    Canton, Tx
    thats with the body lift
  8. rrogers
    I dont see why you would go through all the trouble of removing it. Looks great to me but its your truck.
  9. Northwoods4x4
    Northwoods4x4 BangBro
    Chula Vista CA
    I think it looks good on there. Throw a leveling kit on and its sitting perfect! :peace:
  10. jparks54
    Canton, Tx
    leveling kit is next and im gonna keep it awhile longer at least till i move out of my apartment this is going to turn into my project truck when i get a new DD so thats why i wanna take it off some time
