Rear brake lines need replacing.
Discussion in 'Tech Info' started by dutchie1973, Dec 3, 2011.
  1. dutchie1973
    dutchie1973 Junior Member
    Trenton, Ontario, Canada
    Just got home from my deployment in Afghanistan, and the driver's side brake lines rusted through and need re-placing. Looks like it's wet near the fuel tank....does the tank need to be dropped to replace the lines? Is there a "how to" in this fourm for braker lines?
    F150 4.6L 4x4 Extended cab. 2001
    Dutchie
    I don't think that there is a write up yet. Do the lines go underneath the fuel tank? Some pics would really help
  3. 97madness
    NO, you can leave the tank on. I've done this twice, but never a write up. Just get under their, follow ur rear line. Im pretty sure is feeds thru the frame, so you will have to feel/look around to be sure. Its a pain, but nothing impossible. I've done brakes on my two trucks from left to right, back to front. Its kinda annoying, since i can do it in my sleep.
  4. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    its not bad
