MY friend has 5 codes! HELP!
Discussion in 'Engine & Performance' started by TFIDDLE, Dec 11, 2011.
  1. TFIDDLE
    He has been driving with these for a while. I just wanta know what is common to cause these codes. BTW, his truck starts shaking and jerking at about 45-50mph.
    p0401
    p1309
    p0301
    p0302
    p0171
  2. supercrewzn
    Sounds like he needs a tune up and maybe a couple of cop's.
  3. TFIDDLE
    me and him are gonna do whatever it is. I mean i know its cops and bank 1 lean and that stuff but there are like 10 things it could be for some of these codes. what is most commmon.
  4. supercrewzn
    Considering it has 2 misfires, I'd start with plugs. When was the last tune up? How many miles?
  5. joh408
    joh408 Full Access Member
    Highlands Ranch, CO
    p0401 and 1309 should be the camshaft position sensor, might be out of sync or faulty. Also possible, is the crankshaft position sensor
    p0301 and 0302 are misfires on cylinder 1 and 2
  6. TFIDDLE
    so misfires should i start with plugs or cops
  7. supercrewzn
    Plugs are alot cheaper than cops.
  8. TFIDDLE
    But these plugs can also strip, right? Im not much on 5.4s
  9. c418
    c418 Full Access Member
    you probably did it already, but make sure the wire is on the plug first, i had a misfire once and the wire was just loose
  10. supercrewzn
    I have no idea Tyler. I asked you for the year and you never told me....
