ball joints
Discussion in 'General Discussions' started by iowaredneck, Dec 20, 2011.
  1. iowaredneck
    i think my passanger side ball joint is going out. when i am driving down the road i can hear it squeak and i hear it squeak when i turn the wheel at low speeds. any thoughts?
  2. supercrewzn
    Sounds like a balljoint to me.
  3. 01f1502wd
    sounds like you need some blinkerfluid...and ball joints.
  4. supercrewzn
    Do you know how to check them??
  5. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    Jack front end up push on wheel at top then bottom watch for movement in then its either ball joints or wheel bearings
    Sent from my SPH-M920 using Tapatalk
  6. iowaredneck
    enlighten me please
  7. TxFx04
    if you really wana check it then take the steering knuckle off and grab the threads of the balljoints and if you can move them around in the joint then its time to replace
  8. iowaredneck
    great thanks
  9. The Batman
    The Batman Rest In Piece
    cold hill ky
    omg...dood....just jack the damn thing up and grab the tire on the sides and then the top and then shake it...if you have play in it do it again and lean in and see where the play is and you'll find the problem balljoint whether it be top or bottom
  10. Darth Bama
    Just take a sharp knife and cut the boots open and look...
