engine bay
Discussion in 'General Discussions' started by jakez, Dec 22, 2011.
  1. jakez
    jakez Member
    Black diamond, WA
    Hey guys i was wondering if anyone can post some videos of there engines idleing? my engine just sounds like it has a SLIGHT tick but idk if its normal? or injectors? so if you can please! i will get a video tommorow so you guys can here my engine. also is the fan on the engine loud?
    i have the 5.4l bye the way:baby:
  2. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    could be an exhaust leak, ford motors tend to make that noise wit a exhaust leak
  3. jakez
    jakez Member
    Black diamond, WA
    how loud of a tick would the exhaust leak be? 1 out of 10, 10 being horrifying bad
  4. DestinationFX4
    What year truck do you have?
  5. jakez
    jakez Member
    Black diamond, WA
    02 f150 xlt 4x4
  6. jakez
    jakez Member
    Black diamond, WA
    and i just changed the spark pl,ugs and torqued to 25lbs
  7. DestinationFX4
    check for exhaust leak then
  8. jakez
    jakez Member
    Black diamond, WA
    whats the best way of doing that? and IF i do have an exhaust leak what should i do?
  9. DHGFX4
    DHGFX4 Junior Member
    RVA/Mechanicsville
    A reputable shop in my area was telling me (after working on my truck) that they would suggest running a higher grade fuel because on cold startups it was pinging a little bit (which was causing it to tick). He said it was common on these trucks. (I've never heard of this before though?)
  10. jakez
    jakez Member
    Black diamond, WA
    what oil filter do you have? because i heard if you use the wrong one it will ping till it has oil all throuhout the engine? or something like that
