Str8t six's Lightning swap thread
Discussion in 'Engine & Performance' started by str8t six, Dec 21, 2011.
  1. str8t six
    str8t six never enough
    Back in VA
    I'm running a LFP quick change lower with The stock size 8# and the stock lightning upper.
    I wanted to run a 2 or 4 pound plus lower but I didn't want to risk it in the winter on the NA block.
  2. Screamin.03HD
    Lexington, TN
    the blocks are the same, as are the internals. you should be fine with the factory lightning setup. i still have the factory pullies and i romp on it all the time. If you go with a 4# or 6# you would really need to get a dyno tune to be safe. but in your case a precanned tune should work.
    Sent from my DROID X2 using Tapatalk
  3. THEPRODJECT01
    THEPRODJECT01 MARKK
    odum , ga
    must show a vid, awsome progress, cant wait to see it finished
  4. str8t six
    Back in VA
    i know the blocks are the same, but i thought the rods and pistons are different, plus forged cranks?
    im using JJ to tune my truck. so its not going to be "canned".
  5. str8t six
    Back in VA
    update for today.
    connected my factory heater hose on the intake
    took out the water pump and realized i forgot i ordered the wrong one. so i have to wait and get a spacer shipped out and it will be here on monday or tuesday.
    installed the alternator
    pulley bridge
    put the blower on
    plenum and throttlebody
    throttle and cruise control cables
    LFP quick change lower pulley
    thats what ive got so far. i need to drop the gas tank again and redo the worn out vent hoses on it. next thing im goin to do is wire up the IC pump.
  6. Screamin.03HD
    Lexington, TN
    nope all our rods are junk. from what i understand all 5.4s had forged pistons and cranks.
  7. Screamin.03HD
    Lexington, TN
    progress is coming along great!
  8. 1998f150wes
    1998f150wes CLASS OF 2013
    Guthrie, OK
    sweet progress so far
  9. lil_dq
    lil_dq Full Access Member
    Union, MO
    Tell me you went with twin 255's on your pump replacement. You may run the risk of starving the motor for fuel with a single set up. Also make sure JJ knows you are using a N/A lower end as the comp ratio is higher than an S/C lower.
    Looking good though. You'll enjoy it!
  10. str8t six
    Back in VA
    ok, they did use the same rods, but the just Lightnings had forged pistons(compression ratio to 8.4:1) and cranks.
    all 5.4's made between 97-01 had the forged crank. All 4v navigators had it. All lightnings/harleys got it as well. 02-04 2v's had a 50/50 shot of getting the forged crank or the cast one.
