Having problems!
Discussion in 'General Discussions' started by TFIDDLE, Dec 29, 2011.
  1. TFIDDLE
    So this is on my friends truck, not mine. Anyone heard of an f150 getting a p0232 code? It wont start, was running fine this morning then started idling rough and died. Now wont start. 1998 f150 lariat supercab with 5.4 I dont have time to explain the whole story, im in the deer woods. Ill checl back with more info in a lil bit.
  2. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    sounds like its a fuel problem. Does the engine crank?
  3. TFIDDLE
    Okay sorry, im back with more details. So his motor has been throwing all kinds of codes lately but still ran remotely fine. It was throwing p0401, p1309, p0301, p0302, p0171 last week. He brought it too my house this morning to do some things and fix it. We put some seafoam in it then let it set, then cranked it and it idled rough which is normal with what seafoam ive done. then i got in it to drive it and when i hit the gas, it died. Then it would not crank. I let it set for about 10 min and it cranked right up but idled weird, then we took fuel line off at the filter to check filter and put it back on. the truck has not cranked since then. just turns over and over. I pulled codes and same codes plus p0304 and p0232. So then we start thinkin fuel pump is out and so far thats the best idea we have because if you take off the air intake and spray starting fluid into the TB, it tries to crank. Also the 40 amp PCM/Battery charging fuse under the hood was shot and we replaced it.
  4. 07Fx2
    Oklahoma
    I would say it's the fuel pump.
  5. TFIDDLE
    on my truck you can hear the fuel pump whirrrrrrring the or whining then you hear like a shot of air when you turn the key on.
    on his truck, all you hear is the shot of air, no whining.
  6. 07Fx2
    Oklahoma
    Lol that's a loud ass fuel pump haha
  7. TFIDDLE
    seriously, should i be hearing his whining??
  8. Eric of Memphis
    munford tn
    Yes t fiddle yoir fine..... On your buddies the fuwl pump is shot
    Sent from my SGH-T959V using Tapatalk
  9. 07Fx2
    Oklahoma
    Sorry just got back from a car accident.. F350 was hauling ass 75mph in a 55 rear ended a jeep crushing the back and the jeep, it rear ended my sisters Toyota corolla lol. So f350 totaled even know they drive it up the ramp haha, jeep crushed had to pull the bumper from the rear wheels and sister car got a screwed up bumper and tweaked the metal lol. I'm just thankful for my two nieces (8 month, 6 year old) are ok. They got a few bumps on their heads and the 6 yr old back hurts. Sorry not hijacking. Lol
  10. TFIDDLE
