I gots a sound
Discussion in 'Engine & Performance' started by Sl33p3r, Jan 16, 2012.
  1. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    It's the motor it makes a tick sound and gets faster as I accelerate I'll try to get a video but I'm not sure it will show up on video.
    Sent from my bad ass phone
  2. schrambo
    schrambo Member
    Fond du Lac
    exhaust
    I know on some years its timing chain slapping against the covers cause the tensioner is getting weak. otherwise exhaust manifold bolts that go to the down pipe fords only came with two bolts per sound that could be your tick look at the two bolts you probbly can see them getting thinner and thinner i had that problem
  3. TxFx04
    someone planted a bomb underneath your truck. next time you start the truck more than likely its gonna explode since its hooked up to your starter
  4. Bdons-SD
    kaboooooooooom!!!
  5. ol'red 98
    ol'red 98 Full Access Member
    Katy, TX
    :ROFLJest:
  6. 97madness
    Check your exhaust out. Mine does what your talking of. My tube that goes from my driver side manifold; to the egr stuff has almost completely rusted through.
  7. supercrewzn
    spark plug bout to blow out head
  8. iowaredneck
    spark plug or timing chain
  9. ak_cowboy
    or its just noisy cuz it's a Ford Modular motor....:birgits_tiredcoffee
  10. Big'un
    Either exhaust manifold gasket or timin chains .... Mine done it and ive replaced both
