Diesels???
Discussion in 'F-250 and F-350 General Tech and Info' started by deboer03150, Jan 22, 2012.
  1. Bdons-SD
    This is a common debate over on the PSD forums. computer based gauges, vs hardwired gauges ha ha. Ive read what you just said, and ive read the exact opposite ha ha.
    either way youre right when you say these things are money pits.. I was just looking at an upgraded turbo like a garrett 38r and its like the cost of a small car ha ha.
    Isn't it the size of a small car though? :jester:
  3. agjake11
    agjake11 Suck my tailpipe
    Rosenberg/Baytown TX
    7.3 turbos are tiny haha. :baby:
  4. agjake11
    38r on left 6.0 powermaxx on right.
  5. FSU FX4
    FSU FX4 Full Access Member
    North Alabama
    Getting 230k before any of those 3 went is awesome. Gotta maintain em all especially the 24v
    Sent from my DROIDX using Tapatalk
  6. Bdons-SD
    Shyeah I know. I'm still pushing 25 lbs though ha ha. I'd like a Garrett power max gtp 38r ball bearing turbo, but that's 1500 bucks I don't have ha ha.
  7. agjake11
  8. deboer03150
    deboer03150 Banned
    Archer, IA (Northwest, IA)
    So to do the new head studs and delete on the 6.0 how hard is that??? I think I'm going to be taking a deisel tech program this fall where I'd be able to work on it there.
  9. Bdons-SD
    I have a 7.3 so I've never looked into it, maybe Jake has a better idea.
  10. agjake11
    it can be done by someone with general mechanical knowledge and skill. the thing is the heads are heavy fuggars and to do them with the cab on is rough on one person but isnt out of the question. it is much easier to pull the cab and do it that way if you have a lift and thats part of the labor charges shops go with.
    if you get a stock 03-04.5 truck youd need to do: oil cooler, egr delete, HG, Check/machine the heads as needed, updated oil drain, updated fuel pressure spring, and coolant filter.
    04.5-07 all the above but add a new STC fitting also since that was updated.
    so its not so much the difficulty of the work but the fact that these heads arent light and its tight to do them cab on. certainly doable. ford master tech can do them cab on in about 8-10 hrs of work
