Looks like ill be doing some weilding
Discussion in 'Engine & Performance' started by schrambo, Jan 30, 2012.
  1. schrambo
    schrambo Member
    Fond du Lac
    Well i cut my cats off the other day just the rears well i couldnt weild the top because you cant get to it so now im going have to drop the down pipe and the exhaust out of the truck to weild it up and re in stall problem is i started outside of work and took the impact with a 15MM socket and buzzed off the one maifold but then used the same socket on the other and it stripped it out..
    Truck sounds like SH*T hardcore
    either i weild this up or order up the long tubes with cats and put that on
  2. Predatory Instincts
    Burger King's bathroom
  3. 01f1502wd
    long tubes FTW!
  4. schrambo
    schrambo Member
    Fond du Lac
    Long Tube i heard are ***** to put in and its alot of money so i dont know what i want to do..
  5. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    weilding a knife? or welding
  6. harley99
    harley99 Full Access Member
    South carolina
    ^:jester:
  7. TxFx04
    hahah welding* i ran into the exact same problem you had. i really wana cut my rears out but i want to weld it solid all the way around and like you said you can't get to the top to weld. so i tried dropping the exhaust from the manifolds and ran into the same problem. i got 3 bolts off and the last bolt i stripped... :facepalm: im gonna get one of those special craftsmen sockets that can remove stripped bolts and try again. plus its a million times easier to weld with the exhaust off the truck
  8. harley99
    South carolina
    if u don't mind ruining a socket you could use one size smaller than actually fits the bolt and beat it on with a hammer.
