frame swap
Discussion in '10th Generation F-Series : 1997 - 2003' started by 1998f150wes, Feb 6, 2012.
  1. 1998f150wes
    1998f150wes CLASS OF 2013
    Guthrie, OK
    what do you guys think of a frame swap like take my 2wd truck and swap my cab onto a wrecked 4x4 frame i have the skill but do it, but you think itll be worth it cause i think itll be cheaper than buying a new truck i mean just the cost of the truck (around 1k-1500) and other misc parts so probably a total of 1700 and a week to do it seems pretty do-able to me just give me some input of what yall think
    if you feel like doing all that work. easier said than done
  3. supercrewzn
    Me and 2 buddies have done have done a frame swap in about 3 days, only working on it about 8 hours a day. This was a s10 though. It is a ton of work but its straight forward and not hard to do.
  4. 1998f150wes
    Guthrie, OK
    yea thats probably the truth but i can recoup some money by parting out stuff i wont need anymore like the lift spindles i can get 200 for them and other suspension parts so i think it would end up being dirt cheap to do it so ill probably do it this summer when im out of school
  5. ak_cowboy
    If you got the time and tools, go for it.
  6. jparks54
    jparks54 Full Access Member
    Canton, Tx
    I'd do it if I wasn't planing on a sas in the future LOL distant future
    posted from my texting machine thingy
  7. 97madness
    If you can get it done. Go for it. I would run/check all the lines and such on the 4x4 frame before dropping the body and stuff on. Clean it up and what not.
  8. 01f1502wd
    if you were closer id lend ya a hand. btw what spindles do you have? and are they 3 or 3.5 and u runnin a coil spacer or lift spring?
  9. 1998f150wes
    Guthrie, OK
    they are 3.5 and yes i have a 1.5" daystar
  10. 01f1502wd
    what brand spindles? I may be intrested if i cant get any buyers on my lift, I may get the rear done then drop the front and run spindles and springs. i may purchase them from you.
