Bad coil pack won't arc. You have access to a volt/ohm meter? That's your best bet to see of your coil pack is going bad. Sent from my iPhone4 using Tapatalk
Pretty sure dad has one in the shop.. And if not i can find one somewhere... How do i go about using one to check the coilpack?? Sent from my piece of shat.
Follow these steps. http://www.ehow.com/how_4912368_check-coil-packs-voltage-meter.html http://easyautodiagnostics.com/ford_coil_pack/ford_coilpack_tests_1.php Hopefully this helps, these sites explain how to check better then I'll be able to. Sent from my iPhone4 using Tapatalk
