Vacum hose question need help please
Discussion in 'General Discussions' started by MT93COBRA, Mar 8, 2012.
  1. MT93COBRA
    MT93COBRA Junior Member
    Richland,Ms
    I have a 97 f150 xlt 4x4 and I've noticed a hose coming out the intake running into a fitting on the firewall driver side the line is a dealer part according to autozone ! The hose is really dry rotted could this hose cause my truck to have any hesitation at all and make my check engine light stay on ? Any advice is greatly appreciated
  2. Pity7700
    you talking about the hose thats going into the brake booster?
  3. MT93COBRA
    Richland,Ms
    Yes
  4. MT93COBRA
    Richland,Ms
    The hose looks like foam and is brittle
  5. Pity7700
    if its the brake booster hose you should definitely get that replaced. it could case you to have some brake problems if its breaks since it wouldnt be keeping a vaccum condition in the booster. im not sure if that would turn your CEL on or cause the truck to run ****ty. im sure someone will chime in with more info.
  6. MT93COBRA
    Richland,Ms
    Ok thanks will do
  7. Big'un
    Yes itll make the truck run terrible! Replace it right away
  8. lil_dq
    lil_dq Full Access Member
    Union, MO
    You can use regular vaccum hose for that line, the idiots at vatozone have no idea what they are talking about.
  9. Screamin.03HD
    Lexington, TN
    x2 I think its 3/8
    Sent from my DROID X2 using Tapatalk
  10. cowboy
    what these guys said are right on.
