Chirping like a bird
Discussion in 'General Discussions' started by jmurph, Mar 13, 2012.
  1. jmurph
    jmurph Full Access Member
    Michigan
    this started the other day, my truck makes a chirping sound (sounds like a bird chirping) i haven't had time to investigate yet. only does it during acceleration under 20mph. over 20mph it stops, and if i let off the gas pedal it stops.
  2. DestinationFX4
    My dads 250 does it too. Let me know if you find out anything. We've been looking for awhile
    Sent from Sandals
  3. jmurph
    Michigan
    im not alone. haha
  4. Predatory Instincts
    Burger King's bathroom
    Spray some belt dressing on it and see if it stops. If it does... you need a new belt.
  5. jmurph
    Michigan
    i havent noticed when not in gear, i had it in neutral and rev'ed up and held and i couldnt hear it...humm puzzled.
  6. Predatory Instincts
    Does it sound like it is coming from the engine compartment or the drivetrain?
  7. jmurph
    Michigan
    i was just driving through the parking garage at my school, i cannot really tell where it is coming from. when im out in the open with the window up it sound like its coming from the rear of the truck. but while i was in the garage (i also had my windows down its almost 70 degrees dang shame to leave them up) i couldnt tell. im sitting in class now, and was running late haha. around 2:30 i get out of class for a few hours and ill look more into it then.
  8. TxFx04
    idler pulley? belt?
  9. jmurph
    Michigan
    i think this is what i might be leaning toward (because i cant think of anything else it could be)
    the chirp made a lower tone when climbing up the parking garage, than when it did on flat ground. if that helps yall any.
  10. TxFx04
    try spraying the idler pulley with some WD-40. it's the pulley directly to the left of the alternator. if that makes the squeeking stop then get a new idler pulley, it's fairly cheap
