  1. TxFx04
    stock set up is one fan :shocked: it'll be fine.
  2. Pity7700
    I have read that these fans pull a ton of heat, maybe more than the stock fan. I will monitor it with my edge.
    Yea I think that's a good idea. I might do that. I'm going to order that adjustable controller I posted for the one fan.
    Sweet. Can't wait to see the How-To :waytogo:
  4. 97madness
    Same. Ya done yet? LOL.
  5. TxFx04
    how do you mount them?
  6. jmurph
    jmurph Full Access Member
    Michigan
    Jeep guys do that a lot.
    Sent from my communication device using communication software
  7. Pity7700
    LOL I don't think ill have it done till next weekend. Im super busy with work. I gotta order the controller tomorrow.
    You just make some brackets for it. I'm pretty sure it will mount on the mounting area fir the fan shroud . Might have to get some small brackets though.
  8. Pity7700
    Guys should I go with a probe style thermo or a radiator push in type thermo?
  9. ak_cowboy
    Probe type. The Push in ones have been known to work a hole into the radiator :facepalm:
  10. Pity7700
    alright i ordered a DERALE probe type thermo control. question is where should i stick the probe at? is there a place to put it from factory or do i have to make something to put inline with the radiator hose?
    sorry i disappeared for the weekend dudes lol was out of town. i just finished fitting the fan to the radiator though. fits perfectly. i just have to make a small bracket for the passenger side mount so the fan can be bolted down. my controller should be here tuesday, i hope. i hope to have this installed this weekend. heres a few pics. i will do a full write up when im finished.
    drivers side bolts right up
    passenger side is a little off, need a small bracket.
