Does this look right?
Discussion in 'Engine & Performance' started by Dawgfan54, May 7, 2012.
  1. Dawgfan54
    Dawgfan54 Full Access Member
    Okay so I'm not an expert whatsoever with engines, but I think this intake air temperature is wrong... It's reading 136degrees...
    It's 80 outside and I have the truck in park...
  2. Dawgfan54
    jumped 10 degrees in 5 minutes...
  3. iFX4
    iFX4 Chief
    Florida
    no thats about right.....mine is normally around the 125-130 area....you have to think about the temperature under the hood....
  4. Dawgfan54
    Still, it's 154 now, I thought it took air out of the fender?
  5. jlyoung08
    but ur jus idling so theres not as much air moving under the hood
  6. cowboy
    yep... If's that way while your moving then you got issues.
  7. iFX4
    iFX4 Chief
    Florida
    The thermometer is in the throttle body I believe and by the time the air gets there its pretty warm from engine heat.
    Sent from my iSmarty 4
    Its fine. It should read 10-20* above outside while you're driving. Idling temps don't mean anything
  9. TxFx04
    mine was about a steady 110 the other day
  10. ak_cowboy
    Fugg Texas :flipthebird:
