Plastidip Questions
Discussion in 'General Truck Discussion for all Generations' started by Big'un, Jun 5, 2012.
  1. Big'un
    Ok im wanting to plastidip my wheels ..... got some questions for the guys whose used it......
    Will it be black or brown?
    Can i spray my whole wheel then cut the pattern i want with a xacto knife and then peel the excess off i dont want on there?
    does it spray blotchy or smooth?
    Any closeup pics of yalls wheels finished would help ......
    im wanting to do my stockers like this
    [​IMG]:waytogo:
  2. DestinationFX4
    It will be more of a flat black, unless you use a glossifier with it.
    You CAN spray your whole wheel, cut your pattern, and then peel the excess, but honestly thats going to be WAY more of a PITA than just taping off in the first place. This stuff does come off, but it definitely will take time to peel it off, and usually you can only peel it in small pieces.
    The spray is a little blotchy, but pretty smooth. The first coat will be blotchy, but after you lay the second coat, it will smooth out. I recommend doing around 4 coats on each wheel. It took me 2.5 cans to do my 4 wheels with 3 coats.
    heres a couple pics of mine -
  3. Big'un
    :hmm: i guess ill just spray em with spray paint then
  4. TFIDDLE
    U can buy a glossy version
  5. TxFx04
    that's gonna look sick!! x2 on 4 coats, the more coats you do the easier it will be to peel off. I've heard of the glossy plastidip but never seen it in person
  6. iowaredneck
    those wheels will look hawt if you do it that way
  7. westtnfx4
    I'm not a fan of any wheel with a chrome ring around the outside. But whatever you want to do is what matters.
  8. str8t six
    str8t six never enough
    Back in VA
    why would you use spray paint, you just polished them!
  9. Big'un
    them wheels look ghey! :jester:
