Ifs f250???
Discussion in 'F-250 and F-350 General Tech and Info' started by ZuluBravoTango, Jun 17, 2012.
  1. ZuluBravoTango
    ZuluBravoTango Full Access Member
    Colorado
    At least it still has leafs too. Not Torsions... but crazy looking beast thats for sure
  2. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    Lol yea, you should see how many chevrolets break on the truck pulls. Their front ends are garbage.
  3. 07Fx2
    Oklahoma
    Also if sleeper weeper ever gets on you can ask him a few since he had a few f250s in that year.
  4. ZuluBravoTango
    Colorado
    Nah.. I dont care that much, and the guy is getting laid off anyway. I just wanted to ask about the funky front end...
  5. Big'un
    need pics
  6. Bogger8658
    Bogger8658 Full Access Member
    Millington TN
    if had leaf springs then it had the TTB that ford used from 1980 all the way to 1996 and the f150 and broncos, till 98 on the 250 HDs and till 86 on the 350s however in 97 and 98 ford had a f250 LD which is the same as the f150 HD with the 7 lug wheels and the same sheet metal as the 97-03 f150s they do indeed use a torsion bar system the 250 LD was dropped in 99 when the superduty was introduced
  7. westtnfx4
    It's actually a good front end. Not a straight axle but it works well.
  8. 01f1502wd
    is this kinda what he had?
    its still around. guys in the desert racing stuff call em I-beams. you can get a ton of suspension travel with em, and can be cheaper made than control arms...sometimes.
    those were 4x4s these are 2wd
    and even a f150 supercrew...
  9. lil_dq
    lil_dq Full Access Member
    Union, MO
    Our LD F250 came on the F150 chassis and had the IFS. Only real diff. was the 7 lug rims, and a little stouter rear leaf pack. Could be one of these.
  10. ZuluBravoTango
    Colorado
    Have to check on monday
