A column for a 94
Discussion in 'Interior' started by al94f150, Jun 22, 2012.
  1. al94f150
    al94f150 Member
    Bartlett
    So i have a 94 ext cab short bed f150 and was wondering if anybody has one of these in theres and throw up a few pics of it. and how eaasy was it to install.
  2. ksingltn
    ksingltn Full Access Member
    Anniston, AL
    what exactly are you looking for? A steering column?
  3. al94f150
    al94f150 Member
    Bartlett
    They call them "A Columns" but they are the gauge clusters that go on the driver side beam between the door and the windshield.
    ProParts 93020 - ProParts ProPod A-Pillar Gauge Pods - Application - SummitRacing.com
    Installation difficulty depends upon what gauges you
    install into them, and the type of wiring/plumbing
    required to each gauge and from each sensor/measurement device.
    On mine it's EGT, requires a pyrometer and it's wire from the
    turbo downpipe to the gauge.
    Trans Temp, single wire from trans temp sensor to gauge.
    Turbo Boost Pressure, "hard line" tube and T-fitting from MAP sensor to gauge.
    Also a ground wire to all three gauges and parking or dash light wire
    for night time lighting.
  5. al94f150
    al94f150 Member
    Bartlett
    Thanks for the info. Do you have a pic of yours?
  6. Roush PSD Interceptor
    PTM, it was black, installed in 2003.
    The original A-pillar trim cover is under this one.
  7. al94f150
    al94f150 Member
    Bartlett
    Thanks Man, Now once i get the engine and trans rebuilt i am getting one of these. I really appreciate the help!:)
