decision has been made
Discussion in 'Ford F-250 and F-350 Suspension' started by SUPERxDUTYxV10, Jul 28, 2012.
  1. W.Hirsch
    W.Hirsch Yippie-Ki-Yay....
    Millington, TN
    Lift that **** and get you a gas saver.
  2. Bdons-SD
    ^^^ this!
    I tried it though, Just sold that there jetta I bought not too long ago.. Just needed my truck for work too much. And I hate cars.
  3. Big'un
    i say take the money u was gonna do all that with and drop a 7.3 in it
  4. SUPERxDUTYxV10
    LOS ANGELES
    What gears do u have?
  5. Big'un
    idk , imagine same as u
  6. SUPERxDUTYxV10
    LOS ANGELES
    I think there is 2 different gearing ratios for our rigs
  7. str8t six
    str8t six never enough
    Back in VA
    thats less than 10mpg!!
    F that! drop in a cummins!! :peace:
  8. Big'un
    If im easy i can get 230
  9. Screamin.03HD
    Lexington, TN
    the v10 block is identical to the 5.4 block, bore and stroke is the same just two more cylinders. So you can calculate 25% more fuel consumption to compensate for the other two cylinders. With added parasitic weight in the rotating assembly I would say a solid 30% more fuel consumption than a 5.4 with both trucks in stock trim. With the right gears and tune you should be able to get at least 12-14 MPG lol
    Sent from my DROID X2 using Tapatalk 2
  10. Big'un
    False! Google it ....
