AC not always cold
Discussion in 'General Discussions' started by TxFx04, Aug 13, 2012.
  1. TxFx04
    On a cold start just sitting the AC isn't cold until i get the truck up to speed. Was wondering if it just needs to be recharged or if it's something else like the motor. My friends dudge ram had the same problem and it ended up being the fan motor, once we swapped it out it was cold always. I figured if it was low on freon then it wouldn't get cold at all. :shocked:
  2. UtahFord
    Try recharging it imo
    Sent from my Transformer TF101 using Tapatalk 2
  3. yz85rider2002
    Hook a set of gauges up to it and it'll tell you if your low or not. That'd be we're I'd start
  4. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    A lot of 04-08 09-12 trucks do this. Mine is the same way I'm hoping electric fans fix this.
  5. ustinj7700
    ustinj7700 Member
    Auburn KS
    My dads 05 f-150 had a similar problem, he was about to charge it but checked the pressure and it ended up being about twice what it should be so he bled some out until the pressure was where it should be and it worked fine. Your problem may be completly different but its a possibility.
  6. Predatory Instincts
    Burger King's bathroom
    Welcome to owning a 10th or 11th gen Ford.
    Mine came with a novel hanging from the rearview mirror acknowledging that their AC system sucks and how to get semi cold air the fastest.
  7. ast123
    ast123 Full Access Member
    Mine does exactly the same thing so I thought it needed charging. I bought a guage and checked it and it was perfectly where it was supposed to be. Im still not sure what the problem is...
  8. Roush PSD Interceptor
    I read in some of the A/C tech forums
    they take the orfice tube part # from a van
    and put in the trucks and it will "freeze the balls
    off of a polar bear."
