thought id do some upgrades: from: to: ha thats just a temp solution so the truck drives till i get the blower back. ghetto as ****, but it works ! ive taken it off 3 other times before, so its just the same over and over
yuck! at first I thought all you did was disconnect the innercooler...but now that I look at it you go from charged to N/A. sucks.
that sucks. i have a question tho. whats the reasoning for keeping the stock fan shroud? im assuming you need to run Efans so there is enough room for the intercooler piping or are you able to keep the stock fan with the supercharger?
stock fan with the supercharger. the pipes run inbetween the fan and the radiator. yea the bearings in the blower are SHOT. it was leaking a little oil down to the intercooler, but the noise got ridiculously loud so i knew it had to come off. im gonna rebuild the s-trim....but im gonna work on a T-trim to go in instead ha ha
