  1. cowboy
    you can't bend the pipe mounts to match the pipe?
  2. 01f1502wd
    Nah, ull see
    And boom goes the dynamite.
  3. 01f1502wd
    Moar
  4. 01f1502wd
    the bracket, once tight (should be a 1.25" pipe) it would be tight. but with a small pipe its loose. its a solid mount and doesnt contort much.
  5. TxFx04
    those tires :jester:
  6. cowboy
    You need a spacer pipe between the pipe and bracket like a sleeve and tack weld it to tje pipe
  7. ak_cowboy
    Get some 1/2" thick rubber strips
  8. 01f1502wd
    ^ thats what i did, found an old tire on the side of the road and used stripes from the inside of it.
  9. 01f1502wd
    My LEDS:
    Parking lights
    Fogs
    Big boy bar on roof
    4 hella 700s behind grill
    Im also parked on a slope which doesnt help
  10. Pity7700
    good **** man!
