TLSF150s 95 bronco..
Discussion in 'General Discussions' started by TLSF150, Dec 22, 2012.
  1. TLSF150
    TLSF150 Full Access Member
    Stockbridge, Ga
    **** hubs are 90 a peice.. anyway I can test these or fix them??
    Sent from my SPH-L710 using Tapatalk 2
  2. yz85rider2002
    I'd go with manual hubs man. If the 4wd isn't engaging it's either the actuator or the hubs.
  3. TLSF150
    Stockbridge, Ga
    Thank god its 90 a set not each.. amd yeah if I gotta change em im going with manual hubs..
  4. yz85rider2002
    Our advance sells them up here for about 79 each
  5. TLSF150
    Stockbridge, Ga
    Well I can get a set of manual hubs for less than 100 so thats good... but how do I test the transfer case or any of that other stuff.. im not working full time right now so I definitely cant afford to spend money I dont have too
  6. TFIDDLE
    How much are they at rockauto?
  7. yz85rider2002
    From what it sounds like the auto hubs have bit the dust. You could always jack up the bronco and disconnect the front driveshaft, put the truck in 4hi and put it in drive and see if the front driveshaft spins
  8. iowaredneck
    You figure it out alex??
    sent from area 51
  9. TLSF150
    Stockbridge, Ga
    Im gonna mess with it more today but im pretty sure its the hubs.. so I have to get some manual locking hubs and a conversion kit.. shouldnt cost more than 100
  10. TxFx04
    get that bad boy workin and f*ck up some chevies!
