Bktabolts Slow build thread!
Discussion in 'Under Construction' started by bktabolts, Jun 17, 2012.
  1. bktabolts
    bktabolts Full Access Member
    Uranis
    Thanks!!
  2. BlackThundah
    Trucks looking great.
  3. bktabolts
    Uranis
    Question for whom ever, Is the raptor leaf springs the same size/length as the the 11th gen's?
  4. bktabolts
    Uranis
    Another question, Going to get fox 3.0 coilovers and rear bypass shocks. I don't want to get bulged fenders cause I hate the look. pondering going with a 4" lift but with the 3.0's. Would that give me enough so the tire won't make contact with the fender. I don't want to go any wider, possible a inch or inch and a half. With that said, not going for a all out prerunner, so I won't be taking corners at high speed. Just want a better ride, that is above par of a raptor with out the bulged look. Any help would be appreciated cause going to bit the bullet and start ordering everything. Thanks again!
  5. yz85rider2002
    You should be a good with a 4" kit. Run a fab tech, cst lift, or procomp
  6. bktabolts
    Uranis
    Figured to be safe i'll run some bump stops.
  7. bktabolts
    Uranis
    Little project I have been tinkering with. Had a few lights around the shop.
    8 35w 6k HID.
    [​IMG][/IMG]
    With two in the bumper. I know it's not a ford, but it's still my toy when i'm away!!
    [​IMG][/IMG]
    Camera does no justice.
    So it's a homemade light bar? Looks good!
    sent from my igloo
  9. bktabolts
    Uranis
    Not quite homemade. Modified light bar. Originally had 4 HID's and two IR lights that run off of 24 volt. Squeezing in 8 HID's in that little area was a pain, but the out come is nice. It's a Military vehicle add on light bar. IBISTEK I think makes it.
  10. bktabolts
    Uranis
    Ordered a few need things for the fifty.
    Hate having too many things on my key ring, so...
    [​IMG][/IMG]
    Been looking at bed covers. like the design of this Peragon, so i pulled the trigger and giving it a shot.
    [​IMG][/IMG]
