The keypad on the door.
Discussion in 'Tech Info' started by jamestaylor47, Jan 8, 2013.
  1. jamestaylor47
    jamestaylor47 Junior Member
    Oklahoma
    Is there a way to change the code I bought the truck from a guy and he said he didn't know the code is there a way to reset it?
    Tap Tap
  2. UtahFord
    I think the code is behind the backseat. I could be totally wrong though
    Sent from my PC36100 using Tapatalk 2
  3. cowboy
    there should be a card in the manual too. Not sure how to change the key code
  4. Eric of Memphis
    munford tn
    you cant change the code on it ... the bcm i think is behind the seat on the rear wall dont hold me to that though
  5. Bee89
    Bee89 Super Moderator
    Miami, Florida
    I dont know if the code can be changed but you guys are right. The code is behind the backrest of rear seat on the drivers side.
  6. AKBray907
    Code is behind the rear seat an behind the felt covering, you got to remove the center seat belt at the top center first then a long screwdriver to push two tabs and it'll come out, it's not easy at all, pain in the butt
  7. UtahFord
    Do dealerships have access to get it at all??? R
    The dealer can reset it for you, but they charge $100 for it. (unless you're buddies with someone in the back)
  9. jamestaylor47
    Oklahoma
    I can even get the seats out or down
    Tap Tap
  10. AKBray907
    Dealerships will do it for free depending on the place an you have to show them the title to prove you own it
