Mpg question
Discussion in 'General Discussions' started by Big2ue, Jan 14, 2013.
  1. Big2ue
    Big2ue Junior Member
    Pittsburgh
    Had a new battery installed on Saturday and for some reason my mpg's dropped down to zero miles per gallon. Do you have to reset it manually or does it reset it self?????
  2. Pity7700
    if the battery dies or is unhooked from the truck the computer will reset itself, just like it resets all your radio stations.
    Is it just the display? When you disconnect the battery it erases all the electronic stuff. You probably had to reset all your radio stations too, right?
    Drive around awhile and see if it goes up
    sent from my igloo
  4. Big2ue
    Pittsburgh
    I understand that. But it gave me reading of 0 mpg's. Will it go back up on its own or do it need to be set manually by the driver.
  5. Pity7700
    it should go up as you drive like will said, drive around the block.
  6. Big2ue
    Pittsburgh
    Thanx!
  7. Pity7700
    no problem Quincy
    If it doesn't start going up after a bit, then I would manually reset it.
  9. Big2ue
    Pittsburgh
    How do you manually reset?
  10. ak_cowboy
    What trim truck do you have? Post up a pic of the dash
