New Gent from San Antonio
Discussion in 'Introduction' started by naturalborntex, Jan 7, 2013.
  1. naturalborntex
    naturalborntex Full Access Member
    san antonio
    Im assuming shocks cause it sounds like your shaking a chainlink fence under the truck when you run bumps.
    Edit, tested shocks, they seem fine.. creeking & ricketing from the front passenger when you rock on it, sounds like a fence when you drive though.
    Sent from my SPH-L710 using Tapatalk 2
  2. iowaredneck
    unfortunately it sounds like your ball joints are going out. i have the same problem with mine. i'm waiting till it gets warmer to do mine.
  3. naturalborntex
    san antonio
    They just replaced the front right at the lot ?? Hmm..
  4. 4ctNduction
    T-E-X-A-S
    depending on if the rain goes away or not, we may be going out to the drag strip if you wanna go
  5. cowboy
    well I would bounce test your shocks. Then jack the front up and inspect the ball joints.
  6. VanoFord
    fence creek is typical of a balljoint that is low/out of grease. and you have a UPPER ball joint on the Upper Control arm (entire assembly needs to be replaced for that swap), you have a tie rod ball joint (more than likely what the dealer swapped), and you have a Lower Ball Joint located on the Lower Control arm (this will need to be pressed out, goodyear is inexpensive and good at this).
  7. naturalborntex
    san antonio
    Checked it out more, the control arm bushing for my shock decided it didn't like me anymore lol. Going to replace the bushing instead of buyin new shocks
    Rancho 9000s vs bilsteins anyone?
    Also, when yall goin & where? Id love a trip with y'all, just need to make sure I have the cash! & ill be at the joint tomorrow night!
  8. UtahFord
    Bilsteins
    Sent from my PC36100 using Tapatalk 2
  9. TxFx04
    Another vote for bilsteins
  10. naturalborntex
    san antonio
    Lol, I can definstely try them. Ive loved my ranchos, always done me good
