Factory Y pipe
Discussion in 'Engine & Performance' started by JLOWERY, Mar 8, 2013.
  1. JLOWERY
    JLOWERY Full Access Member
    Paris TN
    Does anyone have a factory Y pipe with the converters that they aren't using? Some idiot cut all the cats of the Super Crew I just bought and run straight pipes. I'm needing the left and right bank to put exhaust back on it.
  2. cowboy
    I will eventually when I get my exhaust redone.
  3. JLOWERY
    Paris TN
    I need one by next week.
    so your whole exhaust is cut off? :think:
  5. JLOWERY
    Paris TN
    Might as well be lol they cut it right below the upper O2 sensors and run straight pipes with 12" glass packs no cats and prob 10 dirt dobber welds that are all leaking.
  6. TxFx04
    :jester: you should get some high flows welded in and call it a day
  7. JLOWERY
    Paris TN
    They still won't run the rest of the exhaust with the hi flows I can get some Magnaflow cats for $68 each but the Muffler shops here are dicks if its not factory they won't touch it.
  8. MyFX4Project
    You just haven't found the right guy. I had a shop quote me 600-800 to run pipes back true dual after my headers and it was going to be cash only because they were "taking a risk" by even touching it. Found a guy in a smaller town to do it for 250 cash plus tax and he had no problem with it. That's going to be better than searching for a y pipe.
    Sent from my Galaxy S3
  9. JLOWERY
    Paris TN
    I can buy a magnaflow direct fit for $450 if I don't find a used one.
  10. BlackThundah
    Check craigslist.
