TxFx04's Build Thread
  1. TxFx04
    so out of my random pile of pipe next to the garage all i got is 2-1/4" pipe (good for 5,625 hp :jester:) so that's too big it would look goofy
  2. AKBray907
    Steel supply, has some 1.5" .120 DOM for under a hundred bucks
  3. TxFx04
    i might see if they got any pipe laying around at work i can use. get some heim joints from... where ever. 4 wheel parts sells them. and i can probably fab up some mounts
  4. AKBray907
    I think you could get some Heims from fastenal here. But if I were you I'd just use bushings an a sleeve.
  5. TxFx04
    yeah that too. probably be alot cheaper. heims are like 40 bucks from 4wp
  6. VanoFord
    man, i need to do some trac bars BAD. my axle wrap is ridiculous. I almost went squirrely this morning while i was going straight down the freeway and just hit the peddle. me no likey.
    so, here's the order we should do:
    trac bars
    projectors
    bumpers
    I might be able to get us a deal on some Heim joints since we would be gettin several.
  7. 01f1502wd
    ^whats your hook up for heims? Ill need 2 for my inner tierods.
  8. TxFx04
    Hahaha sounds good! I might leave the front how it is and just build a rear bumper once I find a design I like
  9. AKBray907
    Personally I don't like Heims for traction bars because they allow the bar to rotate a small amount. Just build some with a threaded bushing an sleeve an it'll be cheaper. No difference in performance.
  10. AKBray907
    Bumper for a purpose or just mainly astetics?
