N/A Power
Discussion in 'Engine & Performance' started by ak_cowboy, Apr 18, 2013.
  1. AKBray907
    Bring it by my shop an ill fix her up right!
    you still need to replace my timing chain tensioners :D
  3. 01f1502wd
    curious, what experience do you have on our 5.4s?
  4. DestinationFX4
    if your going to do cams, may as well do HCI with p&p
  5. AKBray907
    Torn a couple down an rebuilt em, and I've done a bunch of maitanence type stuff. I changed my timing chains a couple months ago stuff like that and time serting heads. Maitanence/repair stuff like that, they're relatively simple engines.
  6. ak_cowboy
  7. TxFx04
    Lol anything engine related can be solved by swapping a 5.0 coyote in according to Bama :ROFLJest:
  8. 01f1502wd
    when the time comes wanna help install cams and aftermarket heads? ill bring the :cheers2:
  9. AKBray907
    Yea just lemme know, you'll have to get the tool to degree the cams, the one I've used was a guy I knew in anchorage. I don't own a degree wheel.
  10. 01f1502wd
    And thats where you come in! Only engines ive worked on are lawn mowers and 4wheelers, not an automobile.
