power steering whine
Discussion in 'General Truck Discussion for all Generations' started by jake wells, Apr 18, 2013.
  1. jake wells
    jake wells Full Access Member
    park city kentucky
    is there anything i can do to get rid of the annoying whine i just changed the fluid in the pump along with the lines and added a filter to it and it is a lot more quiet now, but still annoying. :think:
  2. AKBray907
    Did you get the air out of the system?
    Try some Lucas additive or just swap out the pump. They're pretty easy to get to on those 4.9s
  4. jake wells
    park city kentucky
    yes the air was bleed out i will most likely just change out the pump and add some lucas to the mix. i used type F for the fluid because that is all i had on hand but it is better than what it had in it which was burnt metallic smelling chocolate syrup.
