My 2007 5.4 Cutting out
Discussion in 'Engine & Performance' started by skippyf15, Apr 15, 2013.
  1. skippyf15
    skippyf15 Junior Member
    Belding,MI
    My 2007 5.4 is starting to cut out. Feels like maybe fuel pump trouble. I've had plugs replaced recently. Filled it yesterday and then the wife drove it and it just out of no where the engine started cutting out. Not missing, cutting out. Nurse it to speed to get it to go.
  2. iowaredneck
    Fuel pump or clogged fuel filter
    sent from area 51
  3. DestinationFX4
    Check your FPDM. its a common issue on these trucks if yours in OEM.
  4. cowboy
    I'd start with the fuel filter its simple and cheap.
  5. Pity7700
    start with the fuel filter. easiest and cheapest fix.
  6. Harl0
    Harl0 Junior Member
    Ky
    I agree with destination fx4. Check the FPDM (Fuel Pump Driver Module) it is located on the driver side frame rail above the spare tire. Look through your left rear fender. The module has an aluminum body and is bolted to a steel frame with not much clearance. The fpdm body likes to corrode up to the point where you get a hole in the module and then it goes haywire. It would be a good idea to replace the fuel fikter either way unless replaced recently.
  7. skippyf15
    Belding,MI
    fuel pump module was bad. $327.00 for repairs.
  8. cowboy
    figures... I was hoping it was going to be a cheap easy fix.
