May need a tune?
Discussion in 'Engine & Performance' started by Masonsf150, Jun 2, 2013.
  1. Masonsf150
    Masonsf150 Full Access Member
    St.louis
    So I read people with the 302 are getting 14+ in gas mileage, I am getting around 11 mpg now. City/highway. I have 31" tires, 3.55 gears, e4od trans. I know I had a new distributor put on not too long back, was my step dads truck at that point, but my question is why is my mpg so bad compared to others, I sea foamed the entire engine about 2000 miles age, oil, gas, intake.
    I do have a set of 19 lb, 21 and 24 lb injectors I got in a trade, could my injectors be bad? Or should I consider a tune and if that, where and cost?
    A tune up wouldn't hurt. Get new spark plugs and filters and see how that goes. What psi are your tires at?
    sent from my igloo
  3. Roush PSD Interceptor
    Google search for
    "hypermiling".
  4. Masonsf150
    St.louis
    Ill check the tire psi but I just had new tires put in yesterday.
    Hypermiling-?
  5. Masonsf150
    St.louis
    Searched, ill try new plugs and a air filter first
  6. ak_cowboy
    Get a new fuel filter also. They're cheap and it doesn't hurt.
    sent from my igloo
  7. nflfreak43
    nflfreak43 Full Access Member
    Smyrna, TN
    What can and bed do you have? If its a ext cab long bed 11 is reasonable.. 14 city is hard to achieve unless reg cab short bed
    Sent from my iPhone 4 using Ford Power
  8. Masonsf150
    St.louis
    Fuel filter was replace 4k ago
    And I have a xl- 8ft bed
  9. Masonsf150
    St.louis
  10. nflfreak43
    Smyrna, TN
    What size cab?
