Window Problem HELP!!!
Discussion in 'Audio & Electronics' started by Dawgfan54, Jun 3, 2013.
  1. Dawgfan54
    Dawgfan54 Full Access Member
    Ha English please?
    A small mini computer controller in the master switch.
  3. VanoFord
    this is why my initial post said to go get a whole new master switch. its a MASTER and the rest are a SLAVE. if the Master no worky, the Slave no worky neither.
    I swear if you spray the connectors with electronic cleaner they'll work no problem :jester:
  5. Dawgfan54
    I'm gonna try this ^ after work, I'll let y'all know what happens...
  6. Dawgfan54
    Just sprayed them all and plugged the one in for the back door, with the motor, turned the key for power and it didnt work.
  7. VanoFord
    The driver needs to be connected as well for any of the individual door switches to work by themselves. This is what we were talking about when we mentioned the micro processor and he driver being a Master. Try again and report back.
  8. Dawgfan54
    Okay thank you vano.
    I plugged in the motor and the switch for the back right door. The door will not roll itself up from the back right door.
    However when I press the back right switch and the driver side switch for that same window, nothing happens until I let the back right switch go.
    Then it moves the regulator really slowly up but has no trouble bringing it down.
    I think it's a problem with the master switch?
  9. Dawgfan54
    Bump
  10. cowboy
    I think it's the mini computer
    Sent from my SAMSUNG-SGH-I777 using Tapatalk 4 Beta
